All forms can trigger Ragic's server-side Javascript workflow engine to execute complex business logic, such as calculating costs and posting inventory balance. Basically, any complex business logic that you would like to execute but cannot be covered by Ragic's existing functions can be covered by server-side scripting.
The scripting engine is based on the standard Nashorn Java Scripting Engine that's included in the Java platform. Nashorn supports ECMAScript 5.1, so it would be wise to avoid ECMAScript 6 syntax.
Ragic's spreadsheet design interface can handle most of your data management work, such as creating, editing, and querying records without much problem. On the other hand, manual data maintenance can be a bit time consuming and routine after a while. This is the time when Ragic users will start thinking of ways to automate these processes.
Inside Ragic, there is a pretty powerful scripting engine where you can write Javascript that runs on the server-side, to retrieve data you have on your spreadsheet, make modifications, or even create many records with one click. Typical usage includes updating inventory, creating a new record based on another (creating a sales order from a quote, creating contact from a sales lead), or doing record validation based on database data.
This is the most common and cleanest way to run Javascript workflow, and generally our first recommendataion. You can write your script in the installed sheet scope of your sheet, and configure an action button to execute the script when the user clicks on the button that will be displayed in the "Actions" panel in the lower right side.
To add an installed sheet scope script, just right click on a sheet, and choose Javascript Workflow:
You can then go to the form page of your sheet design, and add an Action Button of the type JS Workflow, and refer to the Javascript function that you have written.
setStatus({id})
Post-workflows are executed immediately after a record is saved. With post-workflow, it's very convenient to automate changes that you would like to make on the record that you just saved that cannot be done with formulas. Or you can make modifications to records on other related sheets, like updating inventory balance.
To add a post-workflow, just right click on a sheet, and choose Javascript Workflow:
And choose Post-workflow from the top dropdown.
A typical post-workflow would look something like this:
var recordId = param.getNewNodeId(key_field_id_of_form);
var query = db.getAPIQuery(path_to_form);
var record = query.getAPIEntry(id);
See our API references and other sections of this document for the list of things that you can do.
Also note that post-workflow will not be executed if you modify entries on listing page.
Pre-workflows are executed before a record is saved, so it can be used as a way of validation to check the data entered against data in the database. Generally most validation can be done with our front-end regular expression checks, or the unique checkbox for free text fields. But for more complex backend checks, sometimes pre-workflow will be needed.
To add a pre-workflow, just right click on a sheet, and choose Javascript Workflow:
And choose Pre-workflow from the top dropdown.
There is a simple example:
Suppose we have a list,
* Key Field: 1000004
* Field Name Field Id
* ID : 1000001
* Price : 1000002
* Name : 1000003
* Available ? : 1000005
function log(str) {
response.setMessage(str);
if(parseInt(newPrice) < 0) {
return true;
if(ifThePriceIsNegative()) {
log('Price is negative !!');
It is noteworthy that we couldn't use entry.getFieldValue while writing the pre-workflow in Ragic (since Ragic haven't saved it). Try to use the param to get old value and new value instead.
Daily workflow runs on a daily basis. It's useful for doing modifications that needs to be refreshed every day. Like updating the results of the formulas based on the current date.
To add a daily workflow, just right click on a tab, and choose Global Javascript Workflow:
By default, daily workflow runs at 19:00 UTC. You can change the execution time and time zone in Company Setting:
1. Go to Account Setup
2. Click Company Setting
3. Select Company Local Time Zone and Daily Workflow Execution Time and save.
If your Company Setting does not have Company Local Time Zone and Daily Workflow Execution Time, please contact us to update it for you.
Approval Workflow are executed immediately after an approval is created/rejected/canceled/finished.
And choose Approval Workflow from the top dropdown.
You can get record id by:
approvalParam is a predefined variable in approval workflow scope.
After you get the above data, you can customize you requirement like this:
if (action === 'CANCEL') {
if (action === 'FINISH') {
Global workflow is a place where you can write Javascript workflow modules that other workflow functions can reference. It will not be exeucted by itself, but can be referenced in any types of the workflow listed above. It's a great place to put scripts that you might need to duplicate across multiple sheets otherwise.
To add a global workflow, just right click on a tab, and choose Global Javascript Workflow:
Form page action button works by configure an action button to call a function you defined in the install sheet scope. When you define the function that the action button calls, you can pass a parameter {id} which is the id of record where you click action button to functions in workflow.
You can see the example at Action Button workflow.
For post-workflow, you can use either the above method just like with pre-workflow. But also there is a convenience method to retrieve the record that was just saved:
query.setUpdateMode();
There is more introduction about how to update records in following section.
If you would like to filter out multiple records, please refer to the section on filtering.
If you want to get more than one records by filtering:
query.addFilter(1000002, '=', 'Green');
query.addFilter(1000008, '=', '2017');
for (var i = 0; i < results.length; i++) {
var entry = results[i];
You can add filters to query by addFilter(fieldId, operator, value), and call getAPIResultList() to get the list of records.
Here's the list of operands that you can use:
Operand Name | Operand Value |
Equals | = |
Regular Expression | regex |
Greater or equals | >= |
Less or equals | <= |
Greater | > |
Less | < |
Contains | like |
You can also use a full text search as a query filter by calling setFullTextSearch(String queryTerm) instead of addFilter().
Let's start with a simple example which retrieves the current record as an object, update its value with a button, and then saves it back to the database. Here is what the demo form looks like:
* AP_Name:wfdemo
* Key Field: 1000013
* Name ID
* No. : 1000011
* Status : 1000012
var STATUS_FIELD = 1000012; //field id of the status field
var query = db.getAPIQuery("/workflow-demo/2"); //get the query object for a sheet with path to sheet
var entry = query.getAPIEntry(recordId); //get the record object for the current record
if (status) {
else {//for switching
var newStatus = entry.getFieldValue(STATUS_FIELD) == 'On' ? 'Off' : 'On'; //get the current value of a field
entry.save();
When writing Javascript workflow, the variable db is predefined. You can reference to it anywhere. Generally we call the method getAPIQuery(pathName) to retrieve the query object for a sheet.
Then you can retrieve a record with its record id on the sheet object with getAPIEntry(recordId), and call setFieldValue(fieldId,value) to set value to a field, or getFieldValue(fieldId) to retrieve value from a record.
Please note that when adding date values, it must be in one of the following formats:
yyyy/MM/dd
yyyy/MM/dd HH:mm:ss
HH:mm:ss
If you're retrieving a value from a multiple selection field, where there may be multiple values, use getFieldValues(fieldId) to retrieve all the values in an array. You can also call setFieldValue(fieldId,value,true) with an extra true argument at the end to specify that you're "adding" an option to the current list of values, not overwriting the existing ones. Note that these operations is only suitable for multiple selection fields.
If you want to copy a multiple selection field value and overwrite the value in anthother multiple selection field, you couldn't just use getFieldValues(fieldId) and setFieldValue(fieldId,value,true). Here's the code that you can refer to:
if (i == 0) {
else {
Please note that you need to retrieve every option and format those options with a vertical bar character (|) like what you will do while importing existing data from Excel or CSV files.
If you're setting values to a file upload field, you can use setFieldFile(int fieldId, String fileName, String fileContent) to create a file with the fileName and with the fileContent you provided. Ragic will then save this file to this field so that the file is available for download on the user interface.
After you're done, just call save() on the record object to save it back to the database.
Creating records are very similar to updating records. Instead of calling query.getAPIEntry(), call query.insertAPIEntry() instead. Like getAPIEntry(), it will also return a record where you can setFieldValue to add field values. The record will be created after calling record.save().
A simple modification of the record update demo like this will create new record instead:
* AP_Name:wfdemo
* Name ID
* No. : 1000011
* Status : 1000012
var entry = query.insertAPIEntry(); //create a new record object
entry.save();
If you have subtables in a sheet, you can also use our API to retrieve data from it, or make edits like the following example. The form looks like this:
The workflow will walk through each row in the subtable, and find the total amount for this year (according to date field in the subtable), the total for the year with the most amount, and identify which year has the highest total. This is designed as a post-workflow, so the three read-only fields will be filled by workflow after the record is saved.
* AP_Name:wfdemo
* Key Field: 1000006
* Date subtable key: 1000007
* No. : 1000001
* Name : 1000002
* Date : 1000003
* Amout : 1000004
* Total of This Year : 1000010
var KEY_FIELD = 1000006;
var AMOUNT_SUBTABLE_ID = 1000007;
var DATE_FIELD = 1000003;
var AMOUNT_FIELD = 1000004;
var MAX_YEAR_FIELD = 1000008;
var yearTotal = {}
if (year in yearTotal) {
yearTotal[year] += amount;
} else {
yearTotal[year] = amount;
var maxYear;
for (var year in yearTotal) {
maxYear = year;
entry.save();
The basic idea is to use getSubtableSize(subtableId) to get the number of rows for a record, and use getSubtableFieldValue(subtableId,subtableRowIndex,subtableFieldId) to retrieve their values. You should be able to find subtable id, field id information in the auto generated comments when you start editing workflow scripts.
You can also use setSubtableFieldValue(subtableFieldId,subtableRootNodeId,value) to set values to a subtable. The subtableRootNodeId is used to specify which subtable row that you're referring to. To find a subtableRootNodeId for an existing subtable row, you can use the following call getSubtableRootNodeId(subtableId,subtableRowIndex) which will return an integer containing the subtableRootNodeId.
If you need to add a row to the subtable, you can use a negative subtableRootNodeId like -100, this way all values set to the same negative subtableRootNodeId will be applied to the same new subtable row, and values set to a different negative subtableRootNodeId like -101 will create different row in the subtable with this different set of values.
var arr = list.toArray();
response.setStatus('WARN');
Link to example: Copy From and Copy To
Copying records is one of the most common workflow program we encounter. We have written a pretty simple function to simplify this type of operation. Let's say we would like to see a record on this sheet:
* AP_Name:wfdemo
* Key Field: 1000022
* S1 subtable key: 1000023
* T1 subtable key: 1000029
* Field name Field ID
* A : 1000014
* C : 1000015
* B : 1000016
* D : 1000017
* S1 : 1000018
* S2 : 1000019
* S3 : 1000020
* S4 : 1000021
* T1 : 1000024
* T2 : 1000025
* T3 : 1000026
function copyEntry(nodeId) {
THIS_PATH:"/workflow-demo/3",
THIS_NODEID:nodeId,
NEW_PATH:"/workflow-demo/4",
COPY:{
1000030:1000014, // A
1000031:1000015, // C
1000032:1000018, // S1
1000033:1000020 // S3
}),response);
br>
br>
Let's take a look at another example.
Here, we want to copy Lin from "CopyFrom" to "CopyTo" and set the status to new. In addition we'd also like to record the created date (please disregard the use of $DATE field for this example).
* field name field id
* From-ID : 1000001
* From-Name : 1000002
* To-ID : 1000004
* To-Name : 1000005
* Status : 1000007
* RegisterDate : 1000008
THIS_PATH:"/entrycopier/1",
THIS_NODEID:nodeId,
NEW_PATH:"/entrycopier/2",
COPY:{
// to : from
1000004:1000001,
1000005:1000002,
}),response);
var current = new Date();
newEntry.save();
You can do some conditional processing based on which groups the user who will be executing the script is in. A user can be in multiple user groups, so usually we can do a user.isInGroup(groupName) call to determine if the user is or is not in this user group. A typical use would be as follows, the following code is designed to be a pre-workflow, but a user object and isInGroup call can be used in all types of workflow except daily workflow which is triggered by the system.
Sometimes you would like to send e-mail notifications based on a set of conditions, or you would like to really customize your notification message content. You can write server-side Javascript workflow for this purpose. Here is the script that you will use to send out e-mail, it's really simple:
mailer.compose(
email, //to
null, //cc
'support@example.com', //reply to
'Acme, Inc.', //displayed from
title,
'Hi '+name+',
we have received your sales order '+'and will be processing your order very soon.
'+'You can see your order details at https://www.ragic.com/example/1
'+'Thanks.
Best Regards,
Sophia, Sales Manager
Acme, Inc.');
mailer.send();
Note that if you would like to send e-mail to multiple recipients, just separate each e-mail addresses with commas.
For attachments, you can use mailer.attach(myURL); to attach a record on Ragic by using the record's URL. For example, here is a record URL on Ragic (always ignore URL after the hash) :
https://www.ragic.com/wfdemo/workflow-demo/2/9
Here is its HTML printer friendly URL:
https://www.ragic.com/wfdemo/workflow-demo/2/9.xhtml
You could start or cancel a record’s approval by adding post-workflow script to your sheet.
First we set the approval step in design mode.
var signers = [];
signers.push({
'stepIndex':'0',
'stepName':'START'
signers.push({
'stepIndex':'1',
'approver':'HR0000@hr.hr',
'stepName':'HR'
autoStartApprover();
result
'stepIndex':'0',
'stepName':'START'
stepIndex :
Used to know which approval step to set, start from zero.
approver :
Used to know who could sign this approval step.
stepName :
Used to set approval step name.
Your approval would not be created if there was something wrong in the parameter format or the approvers you provide didn't follow the rule you set in the design mode.
In this example, if you give the second step parameter like
'stepIndex':'1',
'stepName':'HR'
,it would fail since kingjo@ragic.com was not in the HR group.
We also provide 3 special format for deciding your approvers dynamically according to your company tree.
You could see this for further information.
$DS :
The approver will be set to the user's direct supervisor.
$SS :
The approver will be set to the user's supervisor's supervisor.
$DSL :
The approver will be set to supervisor of previous approver.
The parameter format is like
'stepIndex':'1',
'approver':'$DSL',
'stepName':''
You don't have to provide a non-empty stepName while using these special formats.
Note: If the user in special format didn't follow the rule you set in the design mode, this approver would not be created.
query.setIfIncludeInfo(true);
The approval status will be F is approved, REJ for rejected, P for processing.
You can display a message in a pop-up like this. Please note that the message will only show when the response status is "WARN". By default the message inside the response object will not be displayed since it's usually not helpful to end users.
response.setMessage(message);
In this section we will have an example to show how to use setLimitSize and setLimitFrom. In this example we have 20 entries totally and want to take 6 for each count and show the message.
* ID : 1000009
* Money : 1000010
function limitFromExample() {
var apiQuery = db.getAPIQuery('/entrycopier/3');
// remember the offset
var fromNumber = 0;
apiQuery.setLimitFrom(fromNumber);
// take 6 for each count
apiQuery.setLimitSize(6);
var resultList = apiQuery.getAPIResultList();
while(resultList.length > 0) {
var msg = '';
for(var i = 0;i < resultList.length; i++) {
var entry = resultList[i];
msg += entry.getFieldValue(1000009);
if(i != resultList.length -1) msg += ',';
response.setMessage(msg);
// update offset
fromNumber += resultList.length;
// refresh apiQuery
Entries
Result
util.getURL(String urlstring)
The variable util is predefined.
Also you can call util.setHeader(String name,String value) to set HTTP headers. util.removeHeader(String name) to remove headers.
Method | Description |
getAPIResult() | Get first entry when iterate over the query |
getAPIResultList() | Get array of entries of the query |
getAPIEntry(int rootNodeId) | Get entry by node ID |
getKeyFieldId() | Retrieve the key field id of the sheet this query is on. |
getFieldIdByName(String fieldName) | Get the field id of a specified name. If there are more than one field of the same name, the first independent field id will be returned. |
insertAPIEntry() | Insert a new entry to the query, the method returns the new entry |
addFilter(int fieldId, String operand, String value) | Filtering entries by specified condition |
setIfIgnoreFixedFilter(boolean ifIgnoreFixedFilter) | Set if ignore the fixed filter from target sheet |
setOrder(int orderField, int orderDir) | Sort entries of the query by specified field field id and order direction, parameter orderDir is set to 1 if sort ascending, and set to 2 if sort descending. |
deleteEntry(int nodeId) | Delete entry by node ID |
setLimitSize(int limitSize) | By default ScriptAPIQuery returns 1000 records per query, you can use setLimitSize to change the number of records returned per query. However we do not recommend returning too many records per query because it may take too much memory and have bad performance implications. We recommend using the next method setLimitFrom to do paging instead. |
setLimitFrom(int limitFrom) | This method is for paging through all the records on a ScriptAPIQuery. Setting a limitFrom will tell ScriptAPIQuery to start returning records from an offset so that you can page through all the records of ScriptAPIQuery because ScriptAPIQuery returns 1000 records per query by default. You should check for next page if the number of records returned equals the returned list size. |
setGetUserNameAsSelectUserValue(boolean b) | When set to false, the query will retrieve the user's email for select user fields instead of the user's user name. |
Equals | = |
Greater | > |
Less | < |
Contains | like |
getFieldValue(int fieldId) | Get value of the field by field id. Subtable fields not included. |
getKeyFieldId() | Retrieve the key field id of this sheet. |
getFieldValueByName(String fieldName) | Get value of the field by field name. Subtable fields not included. If there are more than one field of the same name, the first field value will be returned. |
getFieldValues(int fieldId) | Get all the field values from a multiple select field as an array. Subtable fields not included. |
getRootNodeId() | Get root node ID of the entry |
getRootfieldId() | Get root field id of the entry |
getSubtableSize(int subtableRootfieldId) | Get size of subtable, specified by root field id of subtable. |
getSubtableRootNodeId(int subtableRootfieldId, int rowNumber) | Get root node ID of subtable, specified by its root field id and row number in subtable. |
getJSON() | Get a JSON representation of the whole record. |
setFieldValue(int fieldId, String value) | Set value to specified field. For subtable fields, you need to use setSubtableFieldValue(); |
setFieldValue(int fieldId, String value, boolean appendValue) | Set value to a field which is a multiple select field, parameter appendValue need to be true. For subtable fields, you need to use setSubtableFieldValue(); |
setFieldFile(int fieldId, String fileName, String fileContent) | For file upload or graphics field only. A file of the fileName you provided and the fileContent you provided will be created as a file upload and saved to the specified field. For subtable fields, you need to use setSubtableFieldFile(); |
setSubtableFieldValue(int fieldId, int subtableRootNodeId,String value) | Set value to subtable field, you can get parameter subtableRootNodeId by method getSubtableRootNodeId. |
setSubtableFieldValue(int fieldId, int subtableRootNodeId, String value, boolean appendValue) | Set value to subtable field which is a multiple select field, parameter appendValue need to be true |
deleteSubtableRowByRowNumber(int subtableRootfieldId, int rowNumber) | Delete subtable row by its root field id and row number in subtable. |
deleteSubtableRowAll(int subtableRootfieldId) | Delete every row in specified subtable |
deleteSubtableRow(int subtableRootfieldId, int subtableRootNodeId) | Delete subtable row by root field id and root node ID of subtable |
loadAllLinkAndLoad() | Load value of all loaded fields in a link and load configuration in the entry. |
recalculateAllFormulas() | Recalculate every field that contains formula in the entry. |
recalculateFormula(int fieldId) | Recalculate formula of specified field. |
loadAllDefaultValues(ScriptUser user) | Load value of every field that is set with default value, parameter user is predefined. |
loadDefaultValue(int fieldId, ScriptUser user) | Load default value of specified field, parameter user is predefined. |
lock() | Lock the entry |
unlock() | Unlock the entry |
save() | Save a entry |
setCreateHistory(boolean createHistory) | Set if the entry need to create history |
isCreateHistory() | Whether the entry is set to create history |
setIfExecuteWorkflow(boolean executeWorkflow) | Set if executing workflow (pre-workflow and post-workflow) of the entry is needed |
setIgnoreEmptyCheck(boolean ignoreEmptyCheck) | Set if checking not empty fields would be ignored |
setRecalParentFormula(boolean recalParentFormula) | If this sheet is created by subtable of other sheet, or is referenced by other sheet, which means, this sheet has the parent sheet, then you can call this method to set if you want to recalculate the parent sheet or not. |
setIfDoLnls(boolean) | Loaded values syncing will be triggered on the other sheet if that sheet links to this sheet, the source sheet. You should always add this method to the source sheet to trigger syncing on the other sheet. |
getStatus() | Gets the status of the response. Either SUCCESS, WARN, CONFIRM, INVALID, ERROR |
setStatus(String status) | Sets the status of the response. Either SUCCESS, WARN, CONFIRM, INVALID, ERROR |
setMessage(String plainMessage) | Sets a message for display when script executed. This function can be called several times and all messages have been set will show at the same time. |
numOfMessages() | Returns the number of messages that has been set. |
setOpenURL(String url) | Installed sheet scope only. Redirects the user to the url specified after saving the edit. |
setOpenURLInNewTab(boolean b) | Configure whether the browser to open a new tab when opening an URL. Defaults to true. |
getEmail() | Get user's email address |
getUserName() | Get user's full name |
isInGroup(String groupName) | Returns if the user is in this group with the name of groupName |
compose(String to,String cc,String from,String fromPersonal,String subject,String content) | Compose an e-mail message for sending out. The to and cc parameter can contain multiple e-mail addresses. They just need to be separated by commas. |
send() | Send out the message that was just composed. |
sendAsync() | Send out the message that was just composed asynchronously. Note that sendAsync can only be called once per script execution. |
attach(String url) | Attach a file to the message. The URL should be a full URL with https:// |
setSendRaw(boolean b) | Set if the content should not be converted to HTML. Set this to true when your content is already in HTML. |
sendAppNotification(String email,String message) | Send a mobile app notification to this user if the user has installed a Ragic iOS app or Android app. |
sendAppNotification(String email,String message,String pathToForm,int nodeId) | Send a mobile app notification to this user if the user has installed a Ragic iOS app or Android app. The user will be redirected to the specified record when clicking on this notification. "pathToForm" should be in this format "/forms/1", not including the account name, including the tab folder and sheet index. |
getURL(String urlstring) | Calls an URL with GET method |
postURL(String urlstring,String postBody) | Calls an URL with POST method. |
deleteURL(String urlstring) | Calls an URL with DELETE method. |
putURL(String urlstring,String putBody) | Calls an URL with PUT method. |
setHeader(String name,String value) | Sets an HTTP header that will be used in subsequent URL calls. |
removeHeader(String name) | Removes an HTTP header from being used in subsequent URL calls. |
logWorkflowError(String text) | Records a string text log message in the workflow log that you can find in the database maintenance page. |
getUserName(String email) | Get the full name of a user specified by the e-mail address. |
getUserEmail(String userName) | Get the email address for the specified user name. |
reset() | Purge all account related cache when the script and reloads the page finishes executing. |
getTimeZoneOffset() | Get time zone offset of this account in milliseconds. |
getTimeZoneOffsetInHours() | Get time zone offset of this account in hours. |
getUpdatedEntry() | Post-workflow only. Returns the record that was just created or updated. |
getNewNodeId(int fieldId) | Returns the node ID (int) of given field after new value being written. |
getOldNodeId(int fieldId) | Returns the node ID (int) of given field before new value being written. |
getNewValue(int fieldId) | Returns the value of given field after new value being written. |
getOldValue(int fieldId) | Returns the value of given field before new value being written. |
getNewValues(int fieldId) | Similar to getNewValue, but can access multiple values at the same time, which is useful when dealing with multiple-selection fields. |
getOldValues(int fieldId) | Similar to getOldValue, but can access multiple values at the same time, which is useful when dealing with multiple-selection fields. |
getSubtableEntry(int fieldId) | Returns a list of params which can manipulated each record in the subtale. |
create(String[] wfSigner) |
Post-workflow only. wfSigner is an array with specific JSON format objects in it. { 'stepIndex' : what step in the approval - start from 0, 'approver' : approver's email 'stepName' : approver's name or title }
The example for "single approver in a step" : wfSigner push({ 'stepIndex':'1', 'approver':'kingjo@ragic.com', 'stepName':'Jo' })
Note that wfSigner should satisfy the approval you set in design mode. Say, if there is only one candidate "HR00@gmail.com" in step 2 in design mode, you should give a json with approver : HR00@gmail.com and stepIndex : 1 .
cancel() | Post-workflow only. Cancel the approval in the entry. |
getEntryRootNodeId() | Get root node ID of the entry |
getApprovalAction() | Gets the action of the approval. Either CREATE, FINISH, CANCEL, REJECT |
